Wiring Choices
clubcar13
Hey guys,
I am debating on what wire to run. Keep in mind I have both strands of wire. Right now I have Kicker 8 gauge wire going from battery to my speaker amp and now I am hooking up my amp for the sub. I just ordered knukonceptz 4 gauge KLMX cable for my sub amp. I also have a distro block thats 4 gauge in to two fused 8 gauge cables going out.
Now my question is should I just do 2 strands(8 gauge going to speaker amp and 4 gauge going to sub amp) or should I just do the strand of 4 gauge going to the distro block and then running 8 gauge wires to the speaker amp and the sub amp.
My sub amp is going to be a hifonics bxi1606d.
Thanks,
Mike
4 gauge to the sub amp( if possible with your distro block) , then 8 gauge to the highs amp .
I cant do that because its a 4 gauge in and 2 8 gauge outputs. Pretty much I just wanna know if its bad to run 2 different wires. Also, do you guys think that an 80 amp AGU fuse is ok to run to my bxi1606 amp that has two 80 fuses on it?
clubcar13
clubcar13
Boca Raton, FL
clubcar13
