wiring/big 3 questions
09civic
going to be doing JUST the big 3 soon. just want to make sure i know everything before i get into it.
so, for ring terminals and zero gauge...whats the best way to get them on if i dont have a vice or solder?
and how do you even strip zero gauge? lol
and do i NEED new batt terminals?
any help is appreciated
Well without solder, or vice, not sure what to say...typically a vice is like 5-10$ used...and id advise asking friends/family/neighbors for solder. The solder is not needed, but i would rather do it the best way.
Striping it, is fairly easy, just cut a slit in the wire near the end, and then bend it back and forth, then slit it again, and so on, eventually you will get it all the way around, and it'll be just like you striped it and you can pull it off.
New battery terminals, not necessary, but may be easier.
09civic
09civic
Melbourne, FL
09civic
