wiring bd1000.1
  • 2
thaberettakingg
Surrey
i just bought a Rockford bd1000.1 and 2 12"rockford power hx2. the subs are dvc and have 1000rms power. the amp is rated 1000w@2ohms x 1. i want to wire the subs so i get as much power as i can from the amp and can you please find a diagram too. in the future i will get another bd1000.1
you need to wire your subs in "series/parallel"...click on the link below my signature and look on page 6 of my web page for a wiring diagram. wiring the voice coils of each sub in series will yield a 4ohm load per sub and then wiring in parallel to the amp will present a 2 ohm load to the amp.
Do you not have a harness that is plug and play with the OEM wiring? Meaning you buy an aftermarket wire harness, splice the small harness with...
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
438
My brain hurts just looking at those diagrams. It's late so if anyone sees a problem with either of those, please feel free to chime in!
499
554
493
thaberettakingg
thaberettakingg
Surrey
imral3
    Jun 1, 2024
    May 31, 2024
