wiring amp to speakers
hillzz22
Hey, I was previously running 2 Bazooka EL1204 off a Kenwood KAC829 2 channel amp. I've since bought a JBL BP600.1 and hooked it up (killer amp by the way).
Anyways, what i was wondering is this: I would like to hook the old Kenwood amp up to either my front or rear speakers, or both. I am running Infinity 652i coax in the front and Alpine 1629 coax in the rear. Both speakers are 6.5 inch coax and the Infinity's have a highter RMS and peak rating. Would it be better to hook the front or rear or both speakers to the amp? Also, how would I go about doing this? The amp is 2 ohm stereo stable if that helps at all. Also, can I use the power and ground leads and RCA's that i ran for the other amp, or should i use a new ground, etc.? Thanks in advance for your help.
-Aaron
just use the kenwood amp to power your FRONT speakers only. as far as wiring goes... you can jump the rca cords and the remote start wire from one amp to the other but you will need a seperate power source and ground wire. for power (depending on your current wire guage) you can add a distribution block in your trunk to split the power feed. you will also benefit from a cap for the bp600.1.
if you use a 2 channel amp to power both the front and rear speakers you will loose the ability to fade from front to rear. you really dont need to amplify the rear speakers anyway, they are just for "fill".
I have a jeep wrangler 2010 4 door.. So 2 of my speakers are in the dash upfront. And the other 2 are in the bar in the middle of the car
For clarity, why not example 2 ? Example 2 is 2 ohm...my speakers are 4 ohm and amp uses less RMS wattage with the bridged 4 ohm full range...
Wiring question....using four 4 ohm speakers and one 2 channel amp capable of 2.ohm load... Using 2 ohm stable 2 channel 4 ohm amp to power four...
552
In a case like In a case like yours I would rather recommend tactile transducers. They are like woofers without the cone section that are...
994
hillzz22
hillzz22
Willington, CT
hillzz22
    Jun 1, 2024
    May 31, 2024
