Wiring advice, what is worth it?
[quote name='NASTY08IMPALA']Yea @Timmy13091; has a 50ft spool for sale for 65bux...its enough to do the amp and big 3[/QUOTE]
That is to much, by the time i get the rings and inline fuses. I guess i will just go with the first kit i posted. Thank though.
That wire ***** dont waste ur money ..im sure he will sell u half the wire and terminals and fuses
I'm texting him now, I told him i need 7.5 feet+5 ring terminals+ inline fuse for big three upgrade, then i need 22 feet for the power and ground wires off my amp and two ring terminals
U get what u pay for ..hes selling really cheap ...alot of good 1/0 can cost upwards of 5 dollars a foot ..and im willing to bet that 0ga kit from ebay is close to 4ga after u cut the jacket away..just beware
He offered do get me everything for plug and play just for the amp, so power/ground/fuse/rings for 50$ couldn't really say no if it is going to make that big of a difference, but i have cheap rca's too are you sure i shouldn't just buy a different kit?
U can snag a decent set of used rcas on here ..i got some expensive stinger hp3m on here for 20 bucks..he
ell ask timmy hes got some im sure
you know, you can just chill without bass for a while and wait till you have more money and do things the right way first. Or, you can hook everything up and see how low your voltage drop gets and just play around with the gains to make sure its not dropping under 12.
As nasty08impala said, Quantum audio kit is flea market garbage.
No point in buying cheap 1/0 that is going to just like the 4 gauge you have now.
Copper Clad Aluminum seems to be the "trusted" cheaper brand then i can use the wire i have now and do the big 3. Unless RCA's don't make a "huge" difference, then i will just spend the 50 and get the wire from timmy
Yes alot of companies use cca to cut down on cost and it works fine ...but companies like knu execution and sky high to name a few have such high strand count that they make those cheap ebay kits look like 4 ga the only thing that makes that wire look big is the thick plastic jacket..and cheap rcas will be alot less of a problem vs the wire..like i said rcas pop up on here for cheap alot
smtroupe
smtroupe
austin, mn
rfluvinmf
