Wiring advice, what is worth it?
Copper Clad Aluminum seems to be the "trusted" cheaper brand then i can use the wire i have now and do the big 3. Unless RCA's don't make a "huge" difference, then i will just spend the 50 and get the wire from timmy
I have over 150ft of cca in my car thru diff brands i know how they all stack up ..that kca from knu is good stuff as is the sky high execution amd audio technix. Along with the diyma oversized 1/0 .the jacket is a pita on it but wire is beefy
Yes alot of companies use cca to cut down on cost and it works fine ...but companies like knu execution and sky high to name a few have such high strand count that they make those cheap ebay kits look like 4 ga the only thing that makes that wire look big is the thick plastic jacket..and cheap rcas will be alot less of a problem vs the wire..like i said rcas pop up on here for cheap alot
If you have a link to any of those kits for under 50 let me know, all i need is power wire with one terminal and inline fuse, and a ground wire with terminal. ***** balls that i can't find just that for under 50$
smtroupe
smtroupe
austin, mn
rfluvinmf
