Wiring 4 ohm and 6 ohm together??
Im bringin back old general physics knowledge here, so be advised, there may be mistakes ha ha...
P=(V^2/R)
now the Voltage across all resistors in a PARALLEL circuit (not series) is the same. So the variable is the Resistance. so you got a 4ohm and 6ohm resistor...
P1= (V^2/4ohm)
P2= (V^2/6ohm)
compare to ratings, if they dont exceed RMS power handling, you should be set
the power will not be distributed evenly, even if they handle the same power load current takes the path of least resistence so your 4 ohm speaker would get more, in return would probably have one speaker drown out the other. Wouldnt be recomended, i say seperate the subs. what does everyone else say?
They arent subs ... Eclipse 6.5" coaxials (fronts @ 4 ohm) and these random 6.5" mid-bass/woofers (back @ 6 ohm).
I'll see how it sounds. Its not a permanent thing so its not a big deal if sound is perfect. I just want to get the speakers louder and clearer.
def dont do it
97JeepTJ
Pimpin' Jeep ... :P
97JeepTJ
Boston, MA
blackbonnie
