wiring 4 ch. amp bridged...??
budahbuddy803
I have the alpine mrp-f250 bridged using (+) channels 1 and 3 and (-) channels 2 and 4. I know this is correct, but how do i wire my RCAs? Above the white inputs it says ch. 1 and 3 and below the red inputs it says ch. 2 and 4. Do i have to get a splitter and go from 1 pair of rcas to two in order to have all 4 ch. working? Only the right one works at the moment with my RCA plugged into the ch1 and ch2.
You need to have an input to each channel. The easiest method is as you mentioned.....run a single pair of RCA's from the headunit back to the amplifier, then use 2 y-splitters to send those signals to the necessary inputs.
So if you are using channels 1 & 2 bridged to the right side and channels 3 & 4 bridged to the left side, you would use the y-splitter to send the right signal to channels 1 & 2 inputs and another y-splitter to send the left signal to channels 3 & 4 inputs.
man luckily i had a 2 pair of splitters in the garage. I hooked it up and everything is working. Sorry for the dumb question that i figured out on my own.
budahbuddy803
budahbuddy803
Aiken, SC
htownplaya456
