Wiring 2 shivas
Hmm... so the dual 8 ohm coils are essentialy run as a 4 ohm load? So the two 4 ohm loads, wired in parallel make a 2 ohm load. Do I have that right?
Yes sirIts pretty much 2 4ohm subs wired in parallel to crate a 2 ohm final load
Ah ha! It's all starting to come together now! And would you say an amp putting out 600 watts for the pair is about right, or do you have a different suggestion?
Understood. Do you have an amp recommendation? Sorry about all the questions, I'm just trying to learn this shit and what matches up with what.
If you want cheap power,
Look into Profile, ikesound.com sells them for cheap.
If you want a better looking amp a MA Audio M1889i will do it
its 2 ohm mono stable.
There around $120 shipped
Blados
Blados
Baltimore
OLD_SCHOOL
