wiring 2 amps
Alum12Q
Ok.... First im a total newb at wiring... i know how to wire one amp... but i just got a 2400w pyle mono block amp for my bahn and i need to hook it up... do i just hook it up the exact same way as my other amp but just hook the sub to it and the speakers to the other one....???
Well first, you need to fix your sig, its not farat, its farad.... and its not capaciter its capacitor.....
And second, you should buy a distrobution block, mainly a fused one, that will split your power wire into two power wires, but before you do that, whut size power wire are you runnin, cuz if you are gonna be running close to 4400 watts, (the pyle 2000w, and the mono 2400w amp) then i would suggest running like 1/0 and then gettin a distro that splits out to two 2awg, just in case because that is alot of wattage bein ran....
Alum12Q
Alum12Q
Wausau, Wi
Alum12Q
