Wiring 2 2 ohm dvc in separate chambers?
Brometheus
I have two 2 ohm dvc subs in a sealed box. They have their own chambers and their own terminal posts on the box. (One in each side)
How would i wire them to get a 2 ohm load to the amp?
All the diagrams ive seen says to wire the subs in series/parallel.
But there is no way to physically connect em to each other without drilling a hole.
Any input?
Thanks
Wire each up to 4 ohms, the two four ohms subs will then present a two ohm load to the amp. Do you have a mono amp, if so, how many speaker inputs? If you have two sets of pos and neg, when you wire your subs for a four ohm load when you connect to the amp it will 'see' the final two ohm load.
Brometheus
Brometheus
LV-223
Side Show
