250-300 for 1000 watts rms amp
I have a mtx 7801 and there birthsheets go over 1700 rms at 1 ohm ... rated at 1200 @ 1 ohm id sell for 260 shipped. In the us..or best offer+ shipping if anyones intersted
THE NEW CRESCENDO SYMPHANY AMPS!!
packs a punch and has 250 dollar introductory pricing till valentines day
1500 watts at 1 ohm
Symphony S1500.1 - Crescendo Audio | Online Store
Introducing the new Symphony series amplifiers. These amplifiers are the results of over 2 years of from the ground up development.
The goal was to combine high fidelity signal clarity to an extremely efficient Class D full range circuit topology, housed in an ultra-compact newly designed Crescendo Symphony heatsink.
Comprehensive signal processing on the multi-channel Symphony amplifiers, such as bandpass capable crossover circuitry and individual clipping indicators for each channel make the 2 and 4 channel Symphony amplifiers some of the most versatile on the market.
All Symphony amplifiers are capable of being mounted in constricted areas of your car install if needed thanks to the dense form factor and effective design of the heatsinks.
The final outcome of the PCB design enables up to 97% efficiency @ 2 ohms on the monoblock Symphony models and up to 91% efficiency @ 2ohms per channel on the multi-channel models, making them the top tier of efficiency possible in car audio.
what about a massive audio n2 is that a good amp?
---------- Post added at 07:27 PM ---------- Previous post was at 07:26 PM ----------
I can get u an opti 2k for 280 1600 at 1 ohmcheck my site below
i looked at this amp and im wondering if it would be too much for a fi ssd with a flatwound coil
Would be fine just be careful with your Gains, it's always good to have more power than you need so you don't have to push the amp as hard
joede870
joede870
ny
bumpasauras
