Wiring 1700 watt amp to 4 ohm
Just got my new SSA LW1.1700d amp in the mail, unfortunately I only have one working type r to test it out on atm. Is it going to be safe for the sub if I give it 700 watts at 4 ohms. Or even 1200 watts at 2 ohms?
The sub is a 12 inch Alpine Type R DVC 4 ohm.
Voice coils look like this
Im guessing I take one wire from the positive on one voice coil and the other wire from the negative on the other voice coil to get a 4 ohm load from the single sub?
A little bit knowledgeable on this stuff, but just want to be sure haha.
Monoblock stable 1700 watts at 1 ohm, 1200 watts at 2 ohm, 700 watts at 4 ohm.
4x 40 amp fuses.
Signal/Noise ratio >105db
THD .50%
LPF 50HZ-150HZ
Input Voltage Range 11-16 Volts DC
High Impendance RCA/Line Level Input impendance 30k Ohms
Frequency Response is 15Hz-150Hz, 12db
Ok, so I just hooked it up, played a 50hz test tone, while reading the voltage output (AC) from the positive and negative speaker outputs, I was only get from 1-10 volts 10 volts when I turned the bass boost all the way up. The recommended voltage for my setup is 58.3 volts. Did I possibly hook something up wrong? The volume was at 30, the max volume on my deck is around 40 before it starts distorting.
Well you can't wire a DVC 4 ohm sub to 4 ohms...
This. You should've gotten the DVC 2-ohm version and wired it in series to reach a 4 ohm load.
I know it's a Type R' date=' but they're not durable enough to handle 1200w. Not the 12s.
The 15s..maybe.
You could try running it @ 2 ohms, but you'd have to be really careful w/ your gains, etc..[/b']
plantinseeds
Rochester, MN
plantinseeds
