Wiring 1 set of comps with 4 channel amp...
Cadence TXA-3004. I'm so ****** confused...
Cadence Sound Systems
TXA-3004
4 CHANNEL HIGH POWER AMPLIFIER
4 x 75 WATTS RMS @ 4 OHMS
4 x 150 WATTS RMS @ 2 OHMS
2 x 300 WATTS RMS @ 4 OHMS
* FREE BASS REMOTE *
SPECIFICATIONS:
4 Ohm RMS Power: 4 x 75 Watts
2 Ohm RMS Power: 4 x 150 Watts
4 Ohm Bridged RMS Power: 2 x 300 Watts
to bridge you use 1 + and 1 - from the front set speaker connections on the amp. The amp will show which 2 to use. This goes to 1 of your speaker xovers. Then the rear speaker connections are the same but go to your other xover.
to go active, the speakers xovers are not used. you'd run the tweets off the amp's front speaker connections and the mids off the rear connectors. But i don't know if that amp or even your hu provide the xovers you would need.
HU will probably be a Kenwood DNX6960. That the one I;m looking at now. Will probably be ordering next week.
Chassis Size Code DD
CEA-2006 Compliant No
RMS Power Output 22 watts
Peak Power Output 50 watts
RMS Power Bandwidth 20-20kHz
Preamp Outputs 6-channel
Sub Preamp Outputs Yes
Preamp Voltage 5 volts
Display Color Color LCD
Key Button Color Variable
EQ Bands 3
Sound Shaping Type System Q-EX/System E's+
Wireless Remote Yes
Steering Wheel Control Compatible Yes
Security None
Flip-Down Face No
Parts Warranty 2 Years
Labor Warranty 2 Years
Expandability
iPod Connection/Control Optional audio/video
Auxiliary Input Front
USB Input Rear
Memory Card Slot USB memory
A/V Inputs 2
Bluetooth Compatible Built-in
Satellite Radio Ready Sirius
HD Radio Optional
Video Control No
Changer Control No
Tuner
Tuner Type CR-2
FM Sensitivity 9.3 dBf
FM Presets 18
AM Presets 6
European Tuning No
Seek/Scan Seek
Radio Data System (RDS) Yes
CD
CD Frequency Response 20-20kHz
CD Signal-to-Noise 98 dB
Anti-shock Memory None
If that helps. Do you need to see pics of the amp?
OmegaBunny
Moderator
OmegaBunny
Keyser, West Virginia, United States
DukeNut
