Wireing multiple remote turn on wires...
hook them all together....
either split it at some point or jump it from component to component.
Don't be afraid to think for yourself, really - I'm not trying to be sarcastic, although I know it sounds that way.
//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Actually, it's going to depend on the devices and how many there are.
Ideally, if you have to remote turn on more than two devices, you should probably just go ahead and use a relay.//content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
yea if its more then one amp... i would use a relay.. cause amp turn on/0ff "POP" is anoyying.. and that is one of the biggest resons it happens....
i have 2 amps on 1 tiny *** remote and i have no pop. my friend has 1 amp (legacy 4000w //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif) and his shit pops very nicely //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
12v relay for the win
http://cgi.ebay.com/ebaymotors/5-PACK-12V-DC-30A-40A-Bosch-Style-Relay-Socket-SPDT_W0QQcmdZViewItemQQcategoryZ33721QQihZ009QQitemZ190179918865QQrdZ1QQsspagenameZWDVW
85 to 86 is the 12v coil, hook the remote wire to 85, and ground 86
Do not use 87a wire nut it off
Hook 30 to positive
Hook 87 to amp's on leads
Correct me if I'm wrong I'm assuming the diagram is with the 12v coil off.
An easy way to see if i'm wrong/right is to check for continuity with a multimeter on 30-87a. when the 12v relay is not hooked up.
If 30-87a is closed, then I'm right, if it is open, then Use 87a instead of 87.
cuz its a shitty legacy:D
miker
miker
Wayzata, MN
flakko
