wired down to.5 today.
Couldn't you remove your power cable from the amp and your ground cable clamp the batt charger to those?
Would this work since both batts would be connected. And it wouldnt blow a fuse or anything.
I dont see why not, i mean its just an extension from your battery posts at that point. I doubt a trickle charge would blow a fuse.
wait till someone else weighs in before you try it though.
A trickle charge is about 2 amps or less. It wont hurt the fuse. Cant you just connect it at the front battery?
rebelfromva
rebelfromva
VA
OptimaJim
