Wire Size Suggestion
mccanng
Car Audio Learner :-D
268
NC
Should I use a 1/0 to hook up my zx1000.1 or stay with a 4 gauge?
What are the benefits of a bigger wire and what are the downsides (if there are any)?
And what size fuse should I have near the battery if I did run a 1/0 gauge wire?
Thanks Greg
Alright I'm probably going to use 1/0 to hook that amp up and will I notice a difference in the amp?
I will be adding a 4 channel amp next month (probably the Alpine MRP-F600) I'm going to use 4 gauge for that.
LOL no all you need to do is get a distribution block run the 0 gauge into that than run 4 gauge to your amps than 4 gauge for grounds as well. You do not need to run another run of 4 gauge just for your 4 channel.
mccanng
mccanng
NC
on1wheel01
