Wire question
cbrei1023
I am running the system in my sig.
I am wondering how big a main power wire I will need.
If it were you running these amps. Pushing a max of 800W total out of the two amps, what guage wire would you run from the battery to distro block?
Sorry, both amps are bridged so RMS output would be (600x1 & 300x2). I used a DMM to set gains, the sub is set to 500WRMS and the components are on 125WRMS. So Power is 750WRMS, I guess 1500W MAX.
750rms, you should be fine with a 4 gauge run, but I usually go larger.....
I would run a 2 gauge to the block.
Ive never see 2G where can I get it? I was going to get everything from Knu, so maybe I will just go with 0G and then 8G to the 4 channel and 4G to the 2 channel. I am trying to stay as cheap as possible and I already have some 8G lieing around from a previous install.
If you plan to upgrade the amps later, then definitely do the 1/0 now. This will keep you from having to rip it all out and run new wire.//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I bought my 2awg from a hardware store for my big 3
yes at 100% efficiency.....
Sorry, I forgot to factor in the efficiency of his amps. //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
Let's see. No stats on the website, so I will go with 75% efficiency.
That takes him from my first guess of around 60A to a calculated 71A.
You are raight DMAN, that 100A rated wire IS too small.... //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
i never said it was too small....you posted 60A which was wrong and I made sure he knew it wouldn't be 60Amps
Defensive much:confused:
cbrei1023
cbrei1023
Shoey
dman4486
