Is this the 12v swithed wire (bose)? re-q5 install
4Nine
I got the wiring diagram from 12volt. but it does not list every wire
you see in the pic below.
The view is looking at the stock bose amp in the center console of a
99 yukon denali(aka escalade).
I would like to know which wire if any is the 12volt switched in the "Left side harness".
Is it the RED one? (in the diagram it has no mention of a red wire)
Im hooking up a RE-Q5 and thats the only wire Im unsure of.
I assume all the others that arent listed are speaker wires as well except for the 3 I will be using.
Im using rca's from the re-q5 to amps and just need to wire 12v constant,ground,12v switched in from hu to re-q5.
1999 GMC Yukon/Denali Stereo Wiring
Constant 12V+ Orange
Switched 12V+ Yellow
Ground Black
Illumination Gray
Dimmer Brown
Antenna Right Front
Front Speakers 6 1/2" Doors
Left Front (+) Tan
Left Front (-) Gray
Right Front (+) Light Green
Right Front (-) Dark Green
Rear Speakers 6 1/2" Rear Doors
Left Rear (+) Brown
Left Rear (-) Yellow
Right Rear (+) Dark Blue
Right Rear (-) Light Blue
Thanks
4nine
There is no way to tell but it says yellow, there is a yellow wire in the other harness, meter that and see.
If not you can get ACC power from a large gauge orange or brown at the IGN harness.
There is no way to tell but it says yellow, there is a yellow wire in the other harness, meter that and see.If not you can get ACC power from a large gauge orange or brown at the IGN harness.
I was thinking that also but Im assuming all the wires on the right side harness
are for speakers.
If I cant find it there Ill just use the IGN.
Need more help? pm sent
Thanks for the offer..//content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
Is the PINK wire on the right side harness the Amp turn on?
If so cant I just wire the "12v switched in" to that?
4Nine
4Nine
Trinity,FL.
4Nine
