Wire lay out of a 1990 Chevy Cav.
the rear positive are the dark colors
the front positive are the light colors
use and ohm meter to check to make sure you should read about 4-8ohms on each pair of wires
the other trick is to simply open you trunk to check the colors going to speakers
and remove front speaker grilles and speaker in the dash...it is easy screw driver and 7mm heads
you can also use a 9volt battery to pop the speakers.....be careful
awt_daway2b
awt_daway2b
King City MO
ftgu
