Wire gauges i should use!
  • 2
jrmax
oklahoma
I am wiring my amp and everything else so a few ?s on wire.
What size goes to amp gauge wise?
goes to subs?
remote?
ground?
and anything i am forgetting!
It is a 500 watt 4 channel amp powering two alpine type R 12's rated at 300 rms and they are dvc and I will wire them down to 2ohm so the amp is said to put out 1000watts at 2 ohm load but I am estimating 800 or so!
This is what I ordered from Amazon. https://www.amazon.com/gp/product/B07MXMPHKS/?tag=caraudiocom-20...
277
the AVIC was a tad more complicated to wire not to mention stuffing it in a smallish stereo hole. thanks for advice.
771
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
953
It mostly comes down to weight. You can have a super lightweight cone, soft suspension and aluminum coil on a sub and you pretty much get a pro...
945
jrmax
jrmax
oklahoma
geonn
    May 31, 2024
    May 24, 2024
