Wire came unplugged on amp, where do i put it back into?
the order from left to right goes: power, ground, p. con, component outputsits a shitty kenwood
p.con will be the remote terminal. im guessing p.con stands for power controller or something similar which is exactly what a remote wire is.
hell, if you got 2 wires disconnected, 1 is obviously a ground, just use some deductive reasoning. then again, some people would rather still ask first, so i guess i cant blame you. i have more of a "**** it" type of attitude.
Thanks for the help.
Sorry for being such an annoying noob, but there was no way I was going to plug this into a random input without knowing it was right.
Thanks for the help.Sorry for being such an annoying noob, but there was no way I was going to plug this into a random input without knowing it was right.
nothing wrong with that. oh btw, i would try to secure the amp or box or whatever the amp is attached to. you dont want it tugging on the amp again and possible breaking a soldered joint inside leaving you with an amp that needs repairs.
The amp is bolted down with no tension on the wires that I know of. I really have no idea why the wires came out like they did. Maybe the screws for the wires were just loose?
jh95zenki
jh95zenki
New York
jh95zenki
