wire amperage
So its going to carry the same amperage at 12.5 volts that it will carry at 600 volts only because the distance is shorter? IDK about that it has to be less' date=' but I dont know the formula to covert it to find out.[/quote']
you understand current right?
if anything, it would handle more current because its a shorter length!
the voltage doesn't matter when it comes to current.
a 10amp, 120volt mains cable, will handle 10amps at 12volts...
the difference is, that 10amps at 120volts, is 1200watts, while 10amps at 12volts is only 120watts.
Not exactly. Im trying to learn. Thanks for the info. That really cleared it up for me.
Crownvicon28s
God 1st
Crownvicon28s
Spartanburg, SC
Crownvicon28s
