WinPro Signal Generator
DP&MD11
I was just messing around with the signal generator in the program and was wondering if you could somehow create a CD by recording these tones to test in your car. Is there a way to do this? or is there another program that you can do this on? Thanks for the info i was just curious.
And if you should decide you want to try to record them off the winISD Pro program you can.
Open up your CD burner program for data. Then search out the winISD program and open it then you will see all the files to it. Find the sound files and open them. Then drag what tones you want to the burn list.
You should be able to save them as MP3 or WAV files...from there, burn them to disc as you would any other music or data file.
As for how to do that, depends on your burning software. RTFM.
DP&MD11
DP&MD11
Nipomo, CA
JimJ
michigan born
    May 14, 2026
michigan born
    May 14, 2026
