Winners only.
Dah real trap house
”Technically correct” means correct.
RAM is emptied on power down.
Hmmm, you talked about how it’s not some off-the-shelf stuff. That’s a flex.
You talked about not needing GeekSquad to fix the viruses you get, since you have mad skills. That’s a flex.
Who said I was running a modern computer with 98? That’s your comprehension issues at work.
The drive wipes are done by the IT departments. What do they use? I guess that varies by agency. They have to use something robust since the computers store tax data when in primary service.
With a forensic wipe, I’d LOVE to see you or anyone else get data from the drive. An inexpensive program such as WipeDrive will do it, and make the data forensically unrecoverable.
It is certified by the NSA And “Meets Or Exceeds All Major National And International Regulatory And Technical Standards Including:
– Sarbanes-Oxley
– HIPAA
– Common Criteria Evaluation
– FACTA standards
– EAL 2+ security standard
– U.S. Department of Defense 5220.22-M
– CSEC ITSG-06”
A computer guru such as yourself should know about programs like this.
You'd be surprised what can be recovered after a wipe with a readily available commercial product
Literal f*cking SKYNET:
"After all, as prominent computer scientists have been warning us, AI-governed systems are prone to critical errors and inexplicable “hallucinations,” resulting in potentially catastrophic outcomes."
“In fact, the Air Force’s ABMS is intended to constitute the nucleus of a larger constellation of sensors and computers that will connect all U.S. combat forces, the Joint All-Domain Command-and-Control System (JADC2, pronounced “Jad-C-two”).
"Eventually, however, it is expected to link up with the Pentagon’s nuclear command-control-and-communications systems (NC3), potentially giving computers significant control over the use of the American nuclear arsenal."
"According to Admiral Michael Gilday, chief of naval operations, Overmatch is intended “to enable a Navy that swarms the sea, delivering synchronized lethal and nonlethal effects from near-and-far, every axis, and every domain.”"
I see the word “intended” and “expected” a lot.
“Literal“ is not a word that matches up with those others.
Slo_Ride
Regulator
Slo_Ride
ATLANTA
Buck
michigan born
    May 14, 2026
michigan born
    May 14, 2026
