Winners only.
You go one way I go the other way. Hang on to that limited information you have Rob. It is technically correct to a point. For a person such as yourself with limited computer skills that is indeed what your computer does.
”Technically correct” means correct.
RAM is emptied on power down.
Not one time did I flex on my computer nor did I say I need mad skillz to keep it running. You have no idea what you are talking about do you?
Hmmm, you talked about how it’s not some off-the-shelf stuff. That’s a flex.
You talked about not needing GeekSquad to fix the viruses you get, since you have mad skills. That’s a flex.
You need to go read it again.
You think you are running a modern computer with Win98? Who's wiping these computers forensically? You? With what program are these computers being wiped?
Who said I was running a modern computer with 98? That’s your comprehension issues at work.
The drive wipes are done by the IT departments. What do they use? I guess that varies by agency. They have to use something robust since the computers store tax data when in primary service.
Man you sure get defensive and butt hurt don't you.
So you think that when you wipe a drive nothing can be done to recover data huh? Cute.
With a forensic wipe, I’d LOVE to see you or anyone else get data from the drive. An inexpensive program such as WipeDrive will do it, and make the data forensically unrecoverable.
It is certified by the NSA And “Meets Or Exceeds All Major National And International Regulatory And Technical Standards Including:
– Sarbanes-Oxley
– HIPAA
– Common Criteria Evaluation
– FACTA standards
– EAL 2+ security standard
– U.S. Department of Defense 5220.22-M
– CSEC ITSG-06”
A computer guru such as yourself should know about programs like this.
Nothing to see here:
Uhhhh….symbols tell the true story….
“The Balkenkreuz (lit. '"beam cross" or "bar cross"')[1] is a straight-armed cross that was first introduced in 1916–1918 and later became the emblem of the Wehrmacht (German Armed Forces) and its branches from 1935 until the end of World War II. It was used by the Wehrmacht Heer (Army), Luftwaffe (Air Force), and Kriegsmarine (Navy).”
(RESEARCH OPERATION PAPERCLIP - CIA)
I saw lots male fighting aged able bodied Ukrainian refugees when I visited Ireland.
Slo_Ride
Regulator
Slo_Ride
ATLANTA
Buck
michigan born
    May 14, 2026
michigan born
    May 14, 2026
