winISD help needed...
Badfastbusa
Wheelie addict!!!
Ok, i am new at this and needing some help with parameters...
to start with, does anyone happen to have a file or what ever that they could send me that would just input the right parameters like all of the woofers that are already on the program? I am needing the parameters for a alpine 1242 type-r, and it isn't already on the copy that i downloaded which really sucks... i think they have every darn audiobaun sub known to man on there, but no alpine type-r's WTF???
someone please hook me up somehow... i want to get started learning this so i can start designing enclosures for everyone and myself... as of now, i am LOST!
It's pretty hard to screw it up...
I enter the T/S parameters for pretty much every sub I come across for future use. I don't have the Type R though. In the time you spent waiting for a response you could have the manual downloaded and input the stuff into Win ISD, have spent some time playing with the enclosure design and had it figured out.
I don't know what these are:
Mms
Cms
Rms (is this just the RMS like watts of the sub?)
Re (i don't know what to put here because i have 4ohm DVC subs wired to 2ohm)
Bl
Dd
Le
Sd (mine is 480mm Cm^2, it asks for in^2)
fLe
kLe
Hc
Hg
Vd
Xlim
Pe
no
Znom
USPL
SPL
I don't know any of the advanced parameters, and my dimensions are in "mm" and fractions and i dont have a clue how to make them decimals for "in", as you can see, i am having hell.
these are the dimensions that it says on the manual:
320mm
25.21mm
195.1mm
162mm
275mm
my manual don't have:
magnet depth
I don't have a clue what these are either:
VCd
Dvol (which is in^3)
My problem is that it will only input Vas, Fs, and Qts... nothing else. If I put something else in there an error dialog box comes up saying I need to change the values of like Qes, Smax, etc..
Mms-moving mass. DOn't worry about it.
Cms-suspension compliance. Don't worry about it.
Re (i don't know what to put here because i have 4ohm DVC subs wired to 2ohm)-Re is generally stated with the coils wired in series.
Bl-motor strength. There's a spot for it in WinISD
Dd-Driver diameter
Le-voicecoil inductance. Spot for it in Win ISD
Sd (mine is 480mm Cm^2, it asks for in^2)-click on any unit in WinISD and it will change units. Click through until it displays the unit you need.
fLe-don't know so it isn't important
kLe-see above, both have something to do with inductance though
Hc-not important
Hg-not important
Vd-driver displacement
Xlim-the smaller of Xmag or Xmech or Xsus. Basically the maximum usable excursion of the driver
Pe-power handling
no-???
Znom-Nominal impedance
USPL-who knows
SPL-sensitivity
I don't know any of the advanced parameters, and my dimensions are in "mm" and fractions and i dont have a clue how to make them decimals for "in", as you can see, i am having hell.these are the dimensions that it says on the manual:
320mm
25.21mm
195.1mm
162mm
275mm
Divide by 25.4 to convert mm to in. Divide any decimal remainder inch by 0.0625 to get 1/16"
magnet depth
Set the sub on the table and measure from the table to the bottom of the mounting flange.
VCd
Voice coil diamater and driver displacement.
thank you very much for helping us out with that info... (i think) i pretty much got it all in there right... now i really don't have a clue LMAO
I don't know how to put in the box dimensions ect...
Thanks for the help so far... if you don't mind, walk me through this a little...
I am trying to build/design the box now, how do i come to this point? these are the dimensions that i am wanting to build, how do i go about getting to there in this program?
8.8cuft
Tune at 32hz
60"wide
22"tall
it don't really matter how much depth there is, as long as the other 2 dimensions are correct.
I am determined to learn how to do this!
Badfastbusa
Wheelie addict!!!
Badfastbusa
Atoka, OK
Badfastbusa
