Windows login help
dumple
What's in your trunk?
well this mornin i go to use my computer and i go to login usually idont need to type a password because i havent set one but for some reason i try to login and it says ASPNET in the user name and will not let me login i have no clue what to do anyone with help that would be great
I believe that I read a thread on this forum about something similar. Try doing a search. The only way that I've avoided login passwords is through a program called ERD Commander. It allows you to boot from the disc and reset any account password on the machine.
well it just happend this morning so im confused because it usually just boots right up and doesnt even go to the login screen
when you are logged in under your account, or by loggin in safe mode, click on run, then type in "control userpasswords2" and see what accounts are setup to login on this computer. Remove extra ones if need be.
ok but i dont know how to boot into safe mode do i have to go the bios? i cant even get into my account
i had that before when i installed my HP printer drivers, it has something to do with remote access, which is bad
go to your start menu, and click on your little picture, press the back button a few times in the popup window
there will probably be a new user in there besides admin and guest called aspnet or whatever, delete the account for this user
the reason you are prompted to login now is because whatever you installed made another user on your pc so it is wondering which one you are:(
dumple
dumple
Philly
dumple
