Will tuning change with this?
pacho
I'm building a box for my 2 Atlas 15"s and the port dimensions are 7" wide with a 1st height of 17" and 2nd height of 12.5".
--The port is slotted and I'm tuning it to 33 Hz w/7 cubes net, but my question is when im figuring the tuning for the port at this site:
http://www.carstereo.com/help/Articles.cfm?id=31
...since I have 2 different heights, should I add the two heights and divide by 2 to use 14.75" for height??
Thanks for all responses.
It's actually 1 slotted port in the middle of a box with a 15" Atlas on each side of the port. The mouth is 17" high by 7" wide, but the top of the box slopes down with the depth and that's why I have two different heigths in the port.
-Help anyone?
Near impossible can be done
-I'm just trying to figure out what height I'm going to plug in to that site /\ if it should be the mouth of the port, the 12.5" part or 14.75"??
If one of ya'll can tune the box to 33 Hertz w/square slotted port with a 7" wide port mouth X 17" height port mouth with a 2nd height at the back of the port being 12.5" and the box being 7 cubes net. The box is already made-the only thing I can change is the length of the port, already have the port mouth dimensions made so can't change that. If anyone could instruct me how to tune it to 33 Hz by using that site /\ -it would be greatly appreciated and I might throw something your way.
I'll throw something your way if you can help me out-
Edit-I was just wondering since I'm putting two boxes in my car-if I kept the tuning the same on both boxes but had different sized port areas: say 98^2 port area on one and 114^2 port area on the other-would I be running into cancellation issues or is that only when the tunings are different?
pacho
pacho
S.C.
bcarpenterfhl
NorthFramingham
    Jun 30, 2026
