will this work?
I was replying to that... SIMPLY saying that if he got a 4 ohm woofer then there is ZERO way (hints the work impossible) to get a 8 ohm load. I was telling him that for his benefit.
Oops, my bad. For some reason, the forum hasn't been refreshing like it should for me. Those first couple of posts weren't showing when I posted the first time.
My apologies for the misunderstanding.
Anyway, the amp probably won't put out anywhere near rated power. I'd still pick up the 4 ohm sub to make sure that he's getting needed power. Better to have the gains turned down than to be pushing a cheap amp trying to get power out of it. Plus it will make later amp purchases cheaper because he won't need to buy such a big amp.
is there any way to make it a 4 ohm load cuz then id be throwing 600 watts to it
Just get the 4 ohm sub, bridge the amp, and geep the gains down some. All you have to do is wire the + sub terminal to the + terminal on one channel on the amp and the - sub terminal to the -terminal on the other amp channel.
if i were to do this it says i would get 600 watts rms
subwoofers_wiring.html
DeeeeBeeez
Registered User
DeeeeBeeez
my house
denim
michigan born
    May 14, 2026
michigan born
    May 14, 2026
