Will This WORK???? HELP!!!
Korn4Life
SUB LOVE
Ok guys Im about to put the top of my box on and I need to know if you would think this is ok or would u change it.. Because once the top is on it will be very Hard to take these out.... Also when lookin at the pics the box is upside down so the connectors will be on the bottom...
So here are the pics... Im going to put silicone around the bolts and wire terminals on the inside of the box just to make sure they dont ever short out... But do you think it will be ok running it this way?
THanks
Is there a particular reason why you put them on the front of the box as opposed to a side or something?
It'll work fine like that, it just looks weird.
My rear seat is gone in my car.. Were you azz would sit is now going to be my amp rack were you back would be on the seat will be where the face of my box will be.. plus it will be sealed off from the trunk so instead of running the wires through the sheet metal in my car I figured I would put them there.. This makes it only about a foot of wire I have to run...
so u are putting more wire on the outside attaching to the bolts to connect the subs to the amp?
You got it sir... I have about 3/8" of the bolt sticking out the front and I will use that to connect to the amp.... Plus it lets me switch from Parallel to series if need be.... Spelling sucks
Korn4Life
SUB LOVE
Korn4Life
PA
Korn4Life
