Will this old Precision Power 204a (1993) amp run these speakers?
  • Thread starter bullseye
  • Replies 0
  • Views 565
bullseye
Mass
I have a Precision Power 204A 4Ch. amp from 1993 that was used for
http://www.precisionpower.com/Manuals/Amplifier%20Manuals/Precision_Power_Art%20Series%20A204,%20A404,%20AX400%20Amplifiers.pdf
I am finishing up a restoration on a Jeep CJ7 and want to put in a basic 4 speaker system. Will this amp run these speakers? Both speakers are Polk Audio and are marine certified which is perfect for a Jeep that can get caught in the rain from time to time.
(FRONTS)
Polk Audio db521 5-1/4" 135W 2-Way db Series Coaxial Car Speakers
* Woofer Composition: Polymer/Mica Composite
* Top Mount Depth: 2.31 Inches
* Sensitivity: 93 dB
* RMS Power Range : 4-45 Watts
* Peak Power Handling: 135 Watts
* Impedance: 4 Ohm
* Frequency response: 60-22000 Hz
* Diameter: 5.25 Inch
* Design: 2 Way
* Bottom Mount Depth: 2.44 Inches
* Tweeter Composition: Silk/Polymer Composite Dome
(REAR)
Polk Audio db571 5" x 7" 180W 2-Way db Series Coaxial Car Speakers
* Top Mount Depth: 2.19 Inches
* RMS Power Range : 6-60 Watts
* Peak Power Handling: 180 Watts
* Impedance: 4 Ohm
* Frequency response: 52-22000 Hz
* Diameter: 5x7 Inch
* Design: 2 Way
* Bottom Mount Depth: 2.63 Inches
Thanks in advance!
bullseye
bullseye
Mass
bullseye
