will this idea work??
my battery i'm gonna use only has side posts. i need to hook the stock wire, 2 piece of 1/0 gauge, (big 3 and sub amp) and another piece of 4 gauge. i was thinking just get a brass bolt long enough, and i'm all set. does it sound good?
Sounds like it will work to me. I am assuming you are going to be using ring terninals (I hope so). Also I am sure you know but just in case you dont, they make side post to top post converters. So then you can just use a regular battery terminal. Good luck. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
my battery doesn't have top posts. i can't see why it wouldn't work if i get the right size bolt.
No I was saying your idea would work but you could also look into getting a SIDE POST TO top post converter, either way will get the job done.
they make such a thing? i'll have to look into this //content.invisioncic.com/y282845/emoticons/yumyum.gif.0556df42231b304b9c995aefd13928a8.gif
i think i'll try my bolt idea //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Yeah that should work fine, but if not now you have a backup plan. Have fun let us know if it works. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
someone has done it to this car before. the positive side post is missing and has metal terminals and a steel bolt and it is corroded to hell. i figure if i take that bolt out, and get one the same size that's a little longer and brass i should be good to go.
iceteebone
Banned
iceteebone
Michigan
iceteebone
