Will this box handle a 15
XXX's will perform just fine in a sealed enclosure....the problem is your sub is worth $400 and that box is worth $25 (less than that, actually). 5/8" MDF is not worth your time. Do it right the first time.
originally i was going to go for ported, found good plans for 4 cubes, built a mock up out of cardboard boxes and was saddened. the problem is that i wouldn't be able to get the box into the trunk. my trunk is about 32 w X 16 h X 25 d ... the box is 30 x 16 x 23.25 (found it on this site) and i couldn't get it in without bending the cardboard, too bad i can't turn my entire trunk into the box. hehe.
Well, if you HAVE to go sealed. Then go sealed. But for gods sake, just like Gauntlet said, the sub is worth $400, and that box is "$25". Spend the $25 it'll cost to make a box that'll be bigger and more durable.
You can get it in, my trunks dimensions are very similiar to yours, but I managed to fit a 4.3 cuft ported box in there. Look at how tight the fit is:
Just use a little imagination....or a rubber mallet and about a half hour of pounding, like I did. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
agreed gauntlet & biabia, i need to do this right. i'm gonna do a wedge type box with measurements 26.5w X 16h X 11d1 X 18d2 ~ 2.7 -.21 = 2.49 cubes. do i need to do double baffle?
The box is never coming out unless I take a circular saw to it. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
As far as double-baffling, it's not really necessary, but it certainly doesn't hurt. It's worth the extra 4 or 5 bucks and half-hour of time in my opinion.
thedudeabides
thedudeabides
los angeles
thedudeabides
