Will this be enough power??????
maddskillzz
Ok so my setup has changed about 19 times threw the build...changed subs..changed amps...changed wiring...so i am now wondering if my wiring will work..so heres the setup..
Infinity kappas front and rear
component amp (using and old jbl for now bout 400w rms)
Subs 2 RE SE D4 12's
Sub Amps 2 ZX750.1's AKA "THE TWINS" wired at 2 ohm
Knu Konceptz 1/0 wire
stock battery
stock 130 amp alternator
ok so at the moment i have major light dimming and if i am running headlights or heater or something with alot of electrical draw my amps will shut off if i crank it up..
So the question is do you guys think the Big 3 and a new(upgraded) battery up from will be sufficient? This is all in a 95 mustang gt so im really trying to keep the weight down..
Yes probably. Big 3, good wire and new deep cycle batterie(s).Probably want to add a second deep cycle battery to keep the dips to a min.
Get better components. Skip the rear speakers and get some better 6 1/2"'s up front.
this. i have about the same power as you with just a slightly smaller alt. i get no dimming now and my volts stay around 13.6-8 with heavy bass
Are you running 2 batteries?? I really didnt want to add another battery, like i said im trying to keep the weight down.
ok today i did the big 3 and put the new run 1/0 wire in and i will say it helped but my amp guage is still goin nuts and the lights are dimming still...would a major battery upgrade help any?? Like an optima under the hood or am i going to have to add another battery??
what two batteries do you already have? change the weaker one out for a yellow top or something around that.
maddskillzz
maddskillzz
the ville
maddskillzz
vegang
vegang
