Will This Amp Be Enough?
Roswellian
Hey guys, this is my first post here, but Ive bee lurking for the past few weeks.
Ive started an upgrade on my sounds system because I want my bump back and better then ever.
As I said Ive been lurking and reading up for the past couple weeks and now this is what I have ordered (all due in by friday plan on installing this weekend).
x2 TC Sounds TC-1000 12"s DVC 4ohm
Power Acoustik SL-2000d
1.75cube per side ported box
Now from reading and researching on the Power Acoustik amps are overrated, but Ive also seen a few members who are running the 3000db but i could hardly find a word on the new series. So the SL-2000d is rated at 1600w RMS at 1 ohm which is what ill be running (in a perfect world of course). I plan on performing the Big 3 this weekend will rerunning all new power wires as well.
So my question is this I know the Power Acoustik is overrated, but will it still have enough overhead to run the TC-1000s at their rated 400w rms comfortably, or should i not even open it and return it for the sl-2600d.
Thanks
Forum Noob
Roswellian
It will be tuned at 32hz. Its a prefab q-logic. For the moment that is, if I get a chance in the future ill build my own or order a custom made.
{edit}
Once I get everything installed I post what I think of the Power Acoustik Amps since I can find very little mentioned on the forums about them.
And Thanks guys, I was hoping that would be the answer.
Roswellian
Roswellian
Roswell, NM
Roswellian
