Will the big 3 even help me
nba1341
LA
Ok so yea even without big bass beats or whatever just rpm variations for me make my headlights fluctuate along with my interior lights. My amp can be on without any music playing and I still have my headlights going all weird on the freeway.
So if I do the big 3 will it help the problem???
Also right now my negative battery terminal is a 4g wire going straight to the engine block. Is this normal??
its a 1965 mustang nothing is stock though and it was re-wired over a year ago
The big 3 will always help. Your lights may be going bad, or your alternator is going out. I would have it checked.
You should do 1/0 to the engine as well as the frame of the vehicle.
ok i read 15 pages of that thread and now pretty much understand it
so now my question is how in the world do i find out the amps my alternator puts out
if i get a 120a fuse should i be good because i know i have no HO amp
it looks like this
would it have a reading anywhere
it wont help you, check your voltage at idle, and have your alt tested @ autozone.
the wire from alt+ to battery is 16awg and way too long. yes it will help.
when I did 4awg on my maverick I even got better performance.
I do not have slips, but I went from low 9 to upper 8's in the 1/8
why would it be 16ga?
no way its that small...
NBA, im not going to tell you who i am, but i hope all is well from the moddedmustang forums..
Your alternator is shot
haha uhhh
and my alternator isnt shot :/
if anything my battery is because it dies when i leave the accessory switch turned for more than 5 minutes.
it looses a charge pretty fast
nba1341
nba1341
LA
dman4486
Mike Mccabe
