Will sealed generally take more power?
Bobyota
sportin ancient wang
I don't know of every aspect of power handleing, but I know the enclosure is one. I believe I've read that sealed will generally let the sub take more power....true? I may have that backwards, my memory sucks //content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif
I'd appreciate any kind of explanation on how the enclosure affects things //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
For music, yes a small sealed enclosure gives the most power handling (and worst efficiency). But for an SPL setup, ported will actually allow for more power handling because you only run at or near tuning, where cone travel is its lowest.
Thanks y'all. I'm looking at a specific situation, SI's 15" Magnum, or whatever it's about to be called. Haven't found a lot of info on this sub, but I'm interested in seeing how they are changing it up.
If the rms is still rated at 950W, I'll have an amp that's rated at 1200W A 12.5V. My charging system is good, and the amp is an Audiobahn A1300HCX. If they rate this amp right, I'm guessing it may put out around 1300W @14V. I was wanting serious SPL (and SQ), so I thought I'd go with the 4ft @ 28hz box they recomend. Just wondering how much I'll be pusing it and it would compare to sealed....
This is daily for music btw.
even with a ported box run at very high power levels near tuning? I would think that degrades the thermal power handling of the sub, because there is very little to no ventiliation (sp) that cools the voice coils...reduced airflow could lead to more rapid heating...just my silly little observations at 2:22 in the morning, i'm probably wrong.
Bobyota
Bobyota
10-4 town
bigbassman
BP1Fanatic
BP1Fanatic
