Will my subs handle the power??????
Blazer1
I just ordered a Audiopipe AP1500.1D to power two RE Audio 10SRiD2 subs rated at 300w RMS (600w combined), should I set the gain at full power(950w@2ohm) or reduce the gain to achieve 600W@2ohm.
I know most subs will handle more than rated with the correct enclosure and tune and I will loose some power from the amp to the subs so even with the amp wide open my subs my not see 950w.
What should I do, can I run this AP1500.1D wide open?
Can you read??
You are never going to be a mod if you can't read!!
How can a post about helping with amp choice be the same as one questioning the power handling abilities of a sub?
You really are a annoying little shet aren't you,....I made bold some key points to help you determine what each thread is about but I can not do this for every thread. Maybe you can get your mom to come help you?
Can you read??
You could've asked this question in that thread. If you keep making a new thread to ask simple questions people will eventually ignore you. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Do you know how to set gain?half gain isn't half wattage...
I think so?? My plan is to us my DMM and a 60Hz tone and set the a/c output voltage.
I found a nice chart converting a/c voltage to watts but I am not sure where I saw it? I am not sure how this method can be accurate given the fact that true ohms can be difficult to measure and the chart is based on knowing your exact ohm load.
i have the chart i can post it for you..
That will help a lot!
Do you have anything to add about my concerns with static ohms compared to actual ohms? I have my subs wired @ 2ohms but I know this does not mean they are actually resting or working at 2ohms, should I just check the ohms at the box and go by that?
Wire the 2 subs together into a 4ohm load then check that lead with a DMM, pretty simple....
Blazer1
Blazer1
The Hills
Blazer1
