Will my stock electrical be OK
drvsbsm
I'm on a pretty tight budget right now and hopefully this will work on my stock electrical. I have 120 amp alternator, in a 2000 Sebring JXI Limited Edition, convertible. I have to take the tire off to get to the **** battery so I really don't know what size battery is under there yet, but I just bought the car and the guy said he just put the battery in.Here is what I plan to run.
0 gauge OFC Monster wire for power and ground, I'm grounding to the bolts that hold the back seat-belts in. I heard these are good ground points to ground to, they are under my backseat and hold the bracket for the seat-belts.
1st Amp - Audiopipe 1500 watts running at 4ohms in series at about 700-750 watts to a set of Hifonics HFX12D4s rated at 800RMS a set.
2nd Amp - Audiopipe 1500 watts running at 1 ohm in parrelel at about 1300-1400 watts to a set of Hifonics BRZ12D4s rated at 1200RMS a set.
Right now I have a 4 chamber quad sealed box, the subs ask for 1.25 qf and my box is at 1qf per slot, I heard poly-fill can fix this somehow. I bought this box prefab for $50 like I said I had a pretty tight budget, I tried to get some bang for the buck. I know I should have researched a little more, but I heard what I have will bump pretty hard for what I paid.
This would be more efficient than strapping my Audiopipe amps and running all 4 subs at 1 ohm, correct. This would require more power and they are different sets of subs and will most likely have to be tuned separately right.
Also if anyone has a convertible similar to my Sebring what is the best way to get a decent sound in the car, since they are going in the trunk.
Well I'm stuck with the subs and amps I really didnt want to strap them because the reason you stated but will my stock electrical be ok with the 0 guage monster wire running to each amp.?
I've got a 120 amp alt in my Monte Carlo and I can't go much over 1500 rms or so without some pretty good voltage drops. Then again, I haven't done the Big 3 and I'm only running 4 gauge but I have to agree with Nasty08impala. Way too much for stock.......
I have 2004 mountaineer with big three done in 1/0 ofc, and a run of pos and neg straight from batt also in 1/0 ofc. I have a large battery and 140 amp alt. I have a aq 2200 running at 2 ohms so im around 1100 watts and a aq120.4. Thats about all I care to run, my voltage drops to mid twelves. I want to run 2 more twelves eventually, but in doing this I will have to upgrade to one more batt. and high output alt so I know I'm safe.
If I were you I would definately get a volt meter in there and keep a close eye on voltage. It may work... but Personally I dont think it will be safe.
Also I dont know that I would run two different sets of subs either. it may work and you might think its loud, but it could definately be better.
Ok, so I'm going to upgrade and just put my install aside for awhile, I gotta go the cheapest route because I'm low on funds right now. I want to keep my equipment safe what is the best budget way to keep my amps up so I could run my equipment safe, could I just run another battery and do the big 3, would that be enough, if so what budget battery would you recommend?
Also can I do the Big 3 doubling up my 4 gauge OFC wire I have a ton of that stuff.
Sell those subs buy 1 or 2 better subs and if you want ( i would ) get another amp and sell those as for the big 3 depending on what you do i would suggest doing your big three in 1/0 guage that just my .02
I cant sell all this I just got it all on recommendations for a budget setup. I paid $120 for each amp and there are youtube videos showing it does about what it is rated 1500 watts, cant beat that really. The subs have really good reviews on them also, and they bang for the money on all the youtube videos Ive saw. This was a budget setup.
Audiopipe test
Notice that test is BEFORE Oscope... it's dirty. You can't run two different subs. It causes cancellation and sounds like butthole. Sell one pair, use that money for something else. You get what you pay for, don't forget it.
If you're going to come on here and ask for advice, don't argue with every single reply that you get. If you already knew the right thing to do, you wouldn't be asking these questions, and you wouldn't be running that gear. I'm not saying don't use it. But sell half of it. You can not run the two different subs. Thus, you only need one amp. Take the money you get from selling half of it, and get a proper box. And prepare to have your standards raised to entirely new levels.
drvsbsm
drvsbsm
Lost In, Ohio
ewadz3006
