Will my amp push my sub
//content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif its clearly stated the sub is a dual 2 ohm sub....
please show me one way to wire that sub to 2 ohms.
IMO you're an idiot.
Tuff guy! No wonder people don't get anywhere on this forum..People like you give this site a bad name...I can't believe mods let this go here..sad...
ive got a Kenwood KAC-9102d amp
mono subwoofer amplifier
500 watts RMS x 1 at 4 ohms (850 watts x 1 at 2 ohms)
variable low-pass filter (50-200 Hz at 24 dB per octave)
variable bass boost (0-18 dB at 40 Hz )
subsonic filter (15/25 Hz, 18 dB/octave )
top-mounted controls
Class D design
CEA-2006 compliant
speaker- and preamp-level inputs
preamp outputs
fuse rating: 30A x 2
4-gauge power and ground leads recommended — wiring and hardware not included with amplifier
15"W x 2-7/16"H x 11-3/4"D
and a Kicker S12L5 solobaric 12
1200 watt Peak
600 watt RMS
2-Ohm
SoloKon™ cone
88.8 dB Sensitivity
20-100 Hz Frequency Response
Up to 20 percent more cone area than regular round subwoofers
Long lasting tinsel leads
UniPlate™ pole piece/back plate
Heat-reducing T-cup top plate
Stamped-steel basket
Rear foam gasket
spring-loaded terminals
i have them just sitting around and wanna put them in my new car. what kinda box/size box should i put it in and still be able to use my trunk lol. also how should i wire them to get the best sound from the equipment i have... i plann to use 4 gage wire with a capacitor. not sure of the alternator size or battire size. they are stock to the car (2004 acura rsx). im also wondering how i should wire the sub to the amp?
thanks for reading ^_^
Where does it say he has 2 subs????
It doesn't.
He has a DVC 2.
Hustla was a bit harsh, you're probably not an idiot, just ignorant. Idiocy is permanent, ignorance can be fixed.
Plus, he piled on which really wasn't needed.
Either (or both) your reading comprehension and/or your understanding of subwoofer impedence and amp stability is flawed.
People get along just fine here, but you will get called out if you post something that's incorrect. This site doesn't have a bad name. Mods will tend to stand behind the guy doing the calling out as long as he's right, and isn't TOO brutal about it. Instead of whining try learning something.
It doesn't.
He has a DVC 2.
Whining? I was responding to him. I have read and It was a mistake/oversite by me? Calling somebody and idiot is rediculas ..Saying mods let this stuff go because this person knows what their talking about makes no sense. There are better ways to interact in forum other than calling someone an idiot when they are wrong. But I guess that just shows your levels of intelligence. People get along here just fine? Look how many noobs get trashed here..You all where new to here and asked the same questions as they did..I'm not a newbie I don't have 8 thousand post cause I don't get on here everyday..So before you try to trash people offer something helpfull not 12 yr old name calling....
I tried to semi-stand up for you...
You're right - I was a newby once too. I didn't post until I felt I had something worth contributing, and when someone informed me I was wrong I either accepted it or argued my point with verifiable facts. You've done neither.
And yes, on a forum with a bunch of 16-30 yr olds if you post incorrect/bad/or just dumb stuff someone will probably let you know about it.
go find a forum with dancing fairys and pink bunnies and mods that give you emotional support when things don't go your way - maybe that will be more your style.
Your no better than the rest of them here. I don't need you to stand up for me them give a back handed remark at the end..But hey you are probably used to talking to 16 yr olds so that explains it..
Telling someone their wrong is fine thats what forums are here for. But to call people straight out like that is weak...Go back and converse with all your 15 & 16 yr old buddies..
jeezus, you ARE an idiot.
CloudMage
CloudMage
VA
jbgarner12
BP1Fanatic
BP1Fanatic
