will it handle it daily??
azzkikr
Hi everyone,
I have two rl-p's on the way and want to know if they will handle my NINe.1 at 1ohm daily in a 1.25cuft. box. (1.25 per chamber) I am guessing that my nine.1 puts out about 1500 rms at 1ohm and 14.4v. Will thay handle it everyday? I want these to last for a long time. THANX in advance.
//content.invisioncic.com/y282845/emoticons/yes.gif.2d6d3882a589966b8145fbc57db57f33.gif
I've heard of people running them over 1000RMS daily a piece. I say set the gain to about 600 RMS per sub, and that way you wont really strain the subs or the amp.
Okay
What is the best way to get an estimate on the output? I know I should use a dmm but I don't have one or even access to one. Is it in anyway the same as a AC,DC current tester. I also can measure impedance. Is there a way to use this stuff to find out??
OkayWhat is the best way to get an estimate on the output? I know I should use a dmm but I don't have one or even access to one. Is it in anyway the same as a AC,DC current tester. I also can measure impedance. Is there a way to use this stuff to find out??
an AC DC current tester / impedance meter? sounds like a DMM to me //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif. Check out the gain setting tutorial in the amplifier section
sure.. a nine.1 wired to 1 ohm will give you between 500 and 750 actual watts after imp rise, lets not factor in voltage //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif. Is that typical, yep.
azzkikr
azzkikr
Batesville,IN
Spkrman
Mike Mccabe
