will it be enough?
Originally posted by nswartley id probably give it about 2cubes at least per sub if you go ported. you might wanna look at just going sealed and give them about 1.5cubes per sub after displacement.
so with the 2 10's go sealed? and what about goin ported with the one 12? and 3.1 internal cubes is the biggest i can go.
Originally posted by BassBoomer so will the one 12" re se ported be louder than 2 10" re se's sealed then?
not necessarily...it depends on your install etc....if you make the box just right it MIGHT be able to be louder. if you have the money, by all means go for the 2 10s and give them 600 each sealed, and you will get better sq. with a ported box it might start to sound a little bit sloppy
Originally posted by nswartley not necessarily...it depends on your install etc....if you make the box just right it MIGHT be able to be louder. if you have the money, by all means go for the 2 10s and give them 600 each sealed, and you will get better sq. with a ported box it might start to sound a little bit sloppy
ok cool ill save and go with the 2 10's.//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
thanks alot:D
Originally posted by BassBoomer ok cool ill save and go with the 2 10's.//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
thanks alot:D
good luck with it //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif check ebay for em, sometimes they go on there for cheap
BassBoomer
Pakelika
BassBoomer
Warren,OR
nswartley
