Will I need an amp?
  • 4
MrTango
Ok, so ive been DIYing an audio setup in my Kia Sorento. My aim has been to get four door speakers and a pair of 6x9s in the trunk. I currently have the four door speakers installed, and I'm in the process of installing the 6x9s.
Will I need an amp for great quality?
If so, What power range will I need?
If I do get an amp, should I wire all the speakers to it or just rig it to the 6x9s?
please ask for any additional specifications if you want them.
cheers!
Kickers : 60 RMS / 120 peak
Boss audio: 350 watts? Could not find anything specific for these. In hind sight i should have gotten kickers for the rear too.
6x9s: 60-70RMS / 140 peak(their box says 280 tho...)
No sound deadening yet. I'm putting this together slowly, though I know it will improve the quality dramatically.
Well you are going about this all wrong front stang should be main focus for you. Then the rears if you haven't bought the speakers yet. I'd suggest asking around here first
Get really good component speakers for the front doors and put a sub in back somewhere - with amps. Forget the rear doors & 6x9's.
925
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
* The fuse at the start of the cable needs to be equal to or greater than the fuse/load at the end of the run. * The cable needs to be capable of...
Thank you for your reply. What if I wire in series for 8 ohm load ? Sorry for my newbie questions, but wouldn't it have better sound quality...
MrTango
MrTango
United States
Jepalan
