mgcauctions09
Ok heres the plan. 2 runs of 1/0 from alt to front battery with a 300 amp fuse on each cable between the alt. and batt for big 3. Then front front batt. the 2 1/0 cables will head back towards the back battery and get fused again with a 300 amp fuse on each cable. Right before the cables reach the battery bank I fuse again with a 300 amp fuse on each cable. The cables are wired into the battery bank and as the cables leave the battery bank to go to the amps they get fused again.
Does this sound right? It will be fused 4 times per run. (8 300 amp fuses) Will I lose alot of current and or voltage?
By the way: Each run is for an ap30001d amp. Cable is Kolossus fleks
