Will i be okay with my stock alt?
  • 4
I have a '06 impreza 2.5i. This model has a 90A alt. Right now i have a kicker dx600.5 but soon want to add a hifonics 1200D for a single sub. This will push around 700W at 2ohms. I plan on doing the big three before i put the new amp in. Will i be okay with the stock alternator with this build?
Maybe get a decent AGM upfront. I ran 1200 watts to my subs and 340ish watts to my front stage on a stock 100A alt for a while without much issue. Without my Big 3 though I had drastic drops.
Okay, how big do you suggest for a battery? And in theory since I'll have the fifth channel disconnected on the 600.5 it should only be pulling around 300.
Most people run bigger wire than they need. It won’t hurt anything and is actually recommended here. Those reducers work great but I’d recommend...
694
If you are going to replace the HU, then the AC unit is not needed. As to which are good to use, I like the Kenwood Excelon, Sony, Alpine and...
313
601
That is the perfect spot to do that. OEM sub may interfere with the new one and cause cancellation.
384
Those NVX are very good indeed. I only have a leftover set because they were originally going into my brothers restomod 68 Chevelle SS and we...
565
dagormz
dagormz
United States
marcos65
    May 16, 2024
    May 16, 2024
