will a jbl 1200.1 be enough for 2 HtX2's?
  • 4
nikosbuddy
I pooped a hammer
the orion Triple X hybrid......
people say 800-1000 watts rms,
using the cone, coil, and spyder of the xxx, but the structure of the h2....
i want to use a jbl 1200.1, itll dish out like 600 or will it do more?
im going to be using the 2 ohm load because each sub is dual 2 ohms...so does anyone wanna help me //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
thanks everyone...
Mike
so ya think it will run ok because i was going to get an amp that does 1500-2000 watts at 2 ohms...but you think just 600-700....should be ok for em?
Mike
It should be sufficient power for 2 hx2 subs 600 watts per sub.
just be carefull you could blow your subs, max RMS for the subs
is around 600 watts RMS.
It should be sufficient power for 2 hx2 subs 600 watts per sub.just be carefull you could blow your subs, max RMS for the subs
I have seen them take close to 1000 safely, but thats beacuse the install was done well
Well I speak from experience. hx2, He2, dvc, c15 all smoked. It's all about what the speaker will handle safely.
the bp1200.1 put's out 1200 watts RMS into 2 or 1 ohm load.
lol read my post fellas, lol its a htx2, a orion h2, with RE xxx parts....lol thanks for your help thou fellas and your concern.
Mike
anyways go from there...
well im going to be using one for the time being....then when i get my other one im going to hook em both up to a 2 ohm load sending them 600 and i was wondering if that would be enough.....
Mike
well im going to be using one for the time being....then when i get my other one im going to hook em both up to a 2 ohm load sending them 600 and i was wondering if that would be enough.....Mike
well from what I understand, the XXX does not need tons of power to get going, I am not sure as to how it will act in the application //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
I didn't see where there was a difference (didn't see a "light" or "lite" version). That said, if you can fit it, then the JBL BassPro SL 2 would...
WANTED JBL 800GTI
Slava Ukraini, Brother! Don't have that amp but good luck and welcome!
I don't think this is ideal, but let's assume you can easily mount all the tweeters. That installing them is going to be really simple, and...
13
Working with undersized material, adjusting on the fly, testing before setting; you sound like and old pro. You are as meticulous as alot of the...
76
6K
nikosbuddy
I pooped a hammer
nikosbuddy
In louisville
denim
Decebal
    Jun 10, 2024
