Will A 2 Channel Amp WorK.......Help!
bones justice
I got a pair of Beyma 8" Midbass Speakers. They are 8 ohms and are 250 watts rms each. i got a pair of beyma bullet tweeters to go with em. the bullets are 4 ohms and are 50 watts rms each.can i use a two channel amp. Run an 8" and a tweeter on a channel. also what ohm load will that make. also what amp is recommended....type and brand?
ud be fine to run the tweets(if they are nomal small tweeters) on the radio speaker wires then the 8's on a good 2 channel, ,
what u should do is wait ang get a set of midrange woofers and a set of crossovers then add ur tweeters onto it
then grab ur 8 mid basses and
theeeeennnn put all those speaks on a 4 chan amp
bones justice
bones justice
Los Angeles
nismos14
