Width on 3 Tens
ok seriously tho. Will 35 be enuff? I wanna keep the front flat tho. No hexagon thing. I was thinking since I have 14 height i could mount the middle ten a little higher than the two bottom.
as in makin the chambers separate?
Separate chambers arn't necessary, and you're better off with one common chamber for a ported application. But you should still have some form of bracing. Use a divider just like it was a separate chamber, but cut out some of the meat so that air can freely pass through. It should end up looking like a +. Or you can just use a 3" or bigger hole saw and put a bunch of holes in the dividers.
JoseMCeee
$tack
JoseMCeee
Bay Area, CA
JoseMCeee
