Why "daily" systems should not count on impedance rise
Since Sundowz brings up the issue, I would love to hear his take on low impedence loads period and how it effects things. Like, effciency, longevity, SQ, heat and electrical systems. I see it everyday on this forum, people asking can this or that amp run at .67 or .5 ohms although it is only rated at say 1ohm. Since the manufactuer stated the thread maybe people will listen. So Jake will you answer those questions? Jake at what impedence do you run your own personal gear at on a daily basis?
If you look at a data sheet you can see that as a transistor gets hot it has a lower current rating... running an amp at a lower impedance increases the current passing through the transistors, heating them up, and progressively lowering their ability to handle the current until something fails.
Dropping an amp to 1/2 ohm doubles the output current (up until the amp just can't put out more at least) and makes everything less efficient so the power supply in turn draws more current, often times inducing more voltage drop which calls for MORE current to maintain the same output level - again, turning into a cycle if it continues until something fails.
Many amps are robust enough to handle this pretty well - but the more you push the amp and the more clipping that goes on you get closer to realizing the impedance chart I posted above for a square wave which can drop down VERY low. That sort of thing can destroy even a very robust amplifier design when you are already running at 1/2 or less of the rated impedance load.
It all started with SPL competition... where you play ONE sine wave at a known impedance so you can get away with a really low nominal load. That is all well and good, but music is not a single sine wave - you do not know what the impedance curve can do and it CAN drop below the nominal load, unlike "common knowledge" on the forums may tell you.
0.7 is probably your DC Resistance - your nominal load is 1 ohm which is what the amplifier is made for.
A typical "0.5 nominal" load is 0.35 - 0.4 DCR.
I do not understand why people can not comprehend the difference between nominal impedance and DCR.
Pretty good information... I was worried there for a bit about the .5ohm load thing but my amps are .5ohm stable and Im putting a .67ohm load on each one. So if I read correctly I should be fine right?
sundownz
Pro Seller
Supporting Vendor
sundownz
North Carolina
DBfan187
